1.yes that picture is what im talking aboutadrians_s13 wrote:are you talking about the spacer that goes between the tie rod end and the knuckle?
when you lower your car, your tie rods are at an angle, instead of being parallel to the ground (kind of like this -> \=/ ). By adding spacers, it would allow the tie rods to be parallel (like stock configuration) to the ground. As far as steering angle, its not necessarily increasing the steering angle, its just gaining back the steering angle that was lost when you lowered your car.
I hope you know that putting spacers between the rack and the inner tierod will do nothing what-so-ever for steering angle...ever.DrJuice164 wrote:So the spacer goes between the rack and the inner tie rod. By pushing the "block" if you will on the inner tie rod away from the rack, you add more linier travel to the rack, thus creating a higher steering angle. As for the bump steer part, I really don't know.
Going to have to disagree with you there. The spacer goes on the threads of the inner tie rod that thread into the rack. This pushes the ball joint on the inner tie rod further away from the rack, this allows for the rod to pivot at larger angles.redsx13 wrote: I hope you know that putting spacers between the rack and the inner tierod will do nothing what-so-ever for steering angle...ever.
The tie rods do become shorter, yes. but really think about it. Shorter tie-rods would result in what? toe-out. Which is a result of lowering your car (common fact). now, in order to fix the toe-out, an alignment shop will lengthen your tie rods (via oem adjustment). This in turn will solve the problem you described in your diagram, thus no steering angle will be lost.pandapants wrote:
Im sorry, but i dont think your right. Your missing something, toe has everything to do with it.pandapants wrote:you're missing the point. yeah you'll have bad toe, but even when corrected, it will still be shorter bc the lca. The Lca would still be horizontally shorter than stock when lowered. Toe has nothing to do with it.
Modified by pandapants at 11:12 PM 6/10/2009
I get what your saying, but you must take into consideration the movement of the steering knuckle and ball-joint mounting point in relation to the inner tie rod mounting point. here...pandapants wrote:you're not getting it, toe has nothing to do with it. Just bc the tie rod is adjustable, doesn't mean the lca is, and that's what affects the suspensions geometry. The ball joints and knuckles are fixed to the lower control arm, so if the lower control arm is pointing upwards, it will obviously be shorter horizontally than an lca in the stock position.
Think of it as a clock. Lets pretend that the minuet hand and hour hand were indeed the same length. One is pointing to 9 (stock) and the other 10 (lowered). Which is closer to the left side of the clock? The one pointing to 9 obviously.
I understand what you're saying about adjusting the tie rod, but you can't adjust it to the length you're saying. The tie rod end that connects to the knuckle, and the ball joint on the lca have to be perpendicular to the ground in order to have 0 toe.
since the lca is not adjustable and at a fixed length, the ball joint on a lowered car will be closer to the chassis than lets say, a stock one. If you were to adjust the tie rod to the length you're saying to compensate for the difference in length, you would simply place the tie rod end past the ball joint resulting in really bad toe in.
As for your diagram, it's just that.... A diagram. It doesn't show any alignment specs or how much the car is initially lowered or even the chassis it's for. It's good info, but is only good for reference.
edit: And if you want the tie rod to pass line 1, go lower.
+1, check these out http://www.gtfactory.jp/cms/page.php?15pandapants wrote:I guess the suspension needs more work instead of adjustable tension rods to correct steering i.e. s14/adj. lca, larger ball joints and or modified knuckles.
