How do remove/install an ECU for a 1994 Q45?
trenee
Car: 1994 Infiniti Q45
I need to replace my ECU and am not sure how to, help!
96Qowner
Car: 1996 Q45
You're in luck - NICO has an article on the subject!
ECU Codes and How To Check Them
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Also FSM is pretty explicit.
http://www.nicoclub.com/FSM/Q45/
Welcome to NICO.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Remove passenger side kick panel, remove three 10 mm bolts holding it in, disconnected harness by loosening the 10mm bolt in the center of it. Use care to pull it straight out so you don't bend any pins.
goody90q45
Car: 1992 Infiniti Q45 (sold)
[QUOTE=qsiguy]Remove passenger side kick panel....QUOTE]
Look for a 1" square flap of carpet that you pull back to uncover the 10mm nut holding in the kick panel. It's about where your passenger's right foot would be if their leg was extended. You'll need to pull out the large trim piece below the glovebox first. No tools required for removing this part.
