how do install racing edpals?
All things Altima Coupe.
frosty606
Car: Nissan altima 2.5s coupe
do i have to take off my reg pedals? or can i jsut put them on top
alphapig
Car: Nissan Altima Coupe S 2.5
Most clip on.
Most look cheap.
Get MOMO.
marlin29311
Car: 2008 Infiniti G35x
Racing pedals generally just install on top of the original pedals. Your gas pedal is plastic and has nothing that needs to be taken off, and installing a pedal ontop is as simple as taking the pedal and securing it down with self-tapping screws.
The brake pedal is more fun, as it is made of steel. You remove the Rubber top part (you just pull it off, it is slid over). From there you have to drill into the pedal to make a hole for the screws, and then you bolt it on.
http://www.ultimatepedals.com does a really good job - I have a set from there, and they were custom cut to match the pedals. Made from high quality aluminum - I like them a lot! ...im at work and don't have pics, but if you want I can try to take them when I get home.
spockrock
Car: Altima Coupe 3.5se
Anyone know if the stock 350z pedals fit ours??
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
I installed "Sparco Grips" in mine and love um. The install is something you can fudge up pretty easily as you have to drill through the steel on the clutch and break. If you drill a whole where a bolt and nut won't fit because of the arm the pedal is connected to you'll have a crooked jacked up looking install. be careful so you don't have to drill twice.
http://www.winecountrymotorspo...d=230
