spitfire7 »
https://forums.nicoclub.com/spitfire7-u36528.html
Mon Mar 19, 2007 5:13 pm
forget the wire direct. if it dosent work then its a problem. i found the problem, a connector. but she was still runnin very bad. so i tried to adjust the timing by getting it to top dead center. and it didnt start at all. so i put the cam angle sensor in the way it was suppose to be and it still didnt start. i was tring to get at top dead center and was still off. what appeared to be top dead center on chamber #1 actually #4. i was so discusted, and just thought it was just backwards so i turned the marks on the cam angle sensor 180 degrees the other way and it started up so perfect i was just stunned in amazement. so all u guys gettin spark and fuel, and it still isnt starting, and u have it at top dead center turn it 180 degrees, and it just might start. good luck.
