How do I wire JDM half amber and half clear to USDM?
silkk
Car: 94 B13
89 S13
07 S2000
I tried connecting it using the old harness but it doesn't work. Also my blinkers blinks hecka fast..
Can someone tell me which wire goes to which or a diagram?
silkk
Car: 94 B13
89 S13
07 S2000
Okay.. I got the amber to light up but the clear still isn't lighting up and now my sidemarkers stopped working also..
zombieman
keep in mind that i don't have sidemarkers because i use to have a silvia conversion before converting back to stock and the fenders were missing them.
all i did was hook up the amber as the light that would come on when originally equipped on the usdm bumper, of course you're force to do this since the bulb fit in there perfectly. as for the white part, i used it as a signal light. so what i did was hook up the bulb that was dangling from my missing side markers. this also fit perfectly. so i would guess if you want both the side markers and the white part of the bumper light to work, you would have to get an extra pair of sidemarkers wires and begin splicing into the signaling lights. hope this help. just want to mention, i wasn't really a big fan of the amber/white light, so i just bolted the usdm cover with the jdm bumper light housing. i love much better like this, one color piece.
Axel Grungy
Car: 2001 G20 5spd
just splice the running light (white) into your side markers. then cut off the stock bulb/harness and wire back in the jdm one.
book-ends
Car: ???? Nissan 240SX coupe S13
Wow. I was under the impression that you could just plug the JDM units into the USDM harness and everything would work fine. That isn't the case? The stock bulb is a dual-filament unit so what's the problem?
I was thinking of buying a set myself, so let everyone know how this pans out!
silkk
Car: 94 B13
89 S13
07 S2000
I cut the USDM harness and put on the JDM one and now my side markers are not lighting up.. I hate my car.
silkk
Car: 94 B13
89 S13
07 S2000
Okay so I have 2 wires on the amber side, black and green with yellow. I connect black to black and green with yellow to green with yellow. That got the signals to work. The clear side has 2 wires also, black and green. I tried connecting black to black and green to green but it doesn't work.
I can't splice into my sidemarkers because ever since I tried putting in these lights, my sidemarkers and gauge cluster stopped lighting up.
Axel Grungy
Car: 2001 G20 5spd
book-ends wrote:Wow. I was under the impression that you could just plug the JDM units into the USDM harness and everything would work fine. That isn't the case? The stock bulb is a dual-filament unit so what's the problem?
i did alot of reasearch before i got mine, there seems to be two different types, one you can just plug in and one you have to splice. silkk and i have the crappy ones you have to splice.
silkk wrote:Okay so I have 2 wires on the amber side, black and green with yellow. I connect black to black and green with yellow to green with yellow. That got the signals to work. The clear side has 2 wires also, black and green. I tried connecting black to black and green to green but it doesn't work.
that is weird i just matched up the wires, and if they didnt match colors i just touched two wires till it lit up. sounds like you have a short somewhere thats messing up your cluster. wish i could help more
silkk
Car: 94 B13
89 S13
07 S2000
Thanks for your help! But i got it working! I used a volt meter to see why I wasn't getting any power. I found out one of my fuses blew. Its weird 'cause it was the tail light fuse that blew.
Anyways, I got it working and took some pictures. Oh btw, anyone know where I can get some 194 bulbs thats brighter than the stock ones? Like 50w or something?
Axel Grungy
Car: 2001 G20 5spd
haha yeah i want some 194s that are pure WHITE and actually light up somewhat
silkk
Car: 94 B13
89 S13
07 S2000
eBay is our best bet..
I'm addicted to eBay.
VinceSez
Car: 1992 Nissan 240sx
send your's to clearcorners.com, the'll make them brighter for a price...
574-240sx
Car: Nissans, Toyotas, Subaru
Looks good, I have both sets of half amber and white on my hatch and coupe. They pluged right in.
