How do I wire for a power antenna?
Post all your Nissan electronics, car audio and stereo questions here!
maxima278
Car: 96 240SX SR20, 69 Ford Pickup, 99 Dodge Ram 1500, 1996 Nissan Maxima, 1997 Nissan Maxima project, 89 Coupe shell
I've got an S14 with no power antenna, and I've got a power antenna laying arround from my S14 parts car. My car is not wired for a power antenna. where would I hook up the wires in order to make it work? I run an alpine head unit. Thanks
maxima278
hello?
PoorManQ45
hello
PoorManQ45
seriously though, where are you going to put the power antenna? Does it fit in the place of your stock non-power one? If so, you *might* be able to use the existing wire that goes to the non-power antenna to turn the power one on and off. This only applies if there's a direct connection between the regular antenna and the HU though. If the antenna just attaches to the body then you'll have to run a new wire
maxima278
It goes in place of the stock antenna. there are wires that were in the parts car that I do not have, so I know I need to run new wires, I just need to know what to hook them to. I've tried just hooking it up to the antenna wire, but that doesn't make it go up.
PoorManQ45
you're going to need a voltage trigger to make the antenna go up. Do a google search. I can't remember the exact name of it though
audtatious
Your Alpine should have a power antenna trigger (usually orange or a blue/white-stripe). The antenna should have a 12v, ground, and trigger wire. Connect the ground, connect the 12v to an accessory connection, then run a line for the trigger to the HU.
maxima278
thanks!
