blownhemi »
https://forums.nicoclub.com/blownhemi-u134237.html
Fri Nov 26, 2010 4:52 am
While on the subject. Last night I went on to inspect and clean my lifters, and I've found that exactly 8 of them seem to be "stuck". (I didn't number them, so I don't know if they're all intake/exhaust). On the other 8, I can easily push in the valves, they move freely. But on these 8, I can't push them in, but I can turn the valves in their housings quite easily. 8-8, it's really suspicious, but I have NFI what this means. They were not stored the right way up, just shoved in a box. I cleaned them some with brake cleaner, and they're soaked in a diesel/gasoline mixture for now. I really hope this unsticks them. But what if it doesn't? I don't feel like disassembling them by hitting them with a hammer. I will break something...
Basically, this whole hydraulic lifter business is so foggy to me. Should the oil leak out of them, when not stored "correctly", as per FSM? What if they were upside down, and the oil leaked out? Shouldn't the oil pressure fill them up again? Should I fill them up (bleed them), before assembling? The lifters should set the valve clearance automatically, which I guess should mean they only need enough oil in them to close the gap, and no more. What if I overfill them when I bleed them, and they get too high up? If I need to bleed them, which oil should I fill them with? The mineral one for the break-in, or the semi-synth or full-synth for after?
