Can you point me in the right direction in finding that?elwesso wrote:Theres a resistnace test in the FSM.
I'll trade you a nice "Muscle Cruiser" style motorcycle straight up .Q_SHIP wrote:also, is an injector resistance check the same as a G50?
Anybody want a lowerd Black black Y33 for $5500. God Im so over this car.
Here you go.Q_SHIP wrote:Can you point me in the right direction in finding that?
You're kidding right?Q45tech wrote:The normal method is to acquire a few NEW coils and 1 by 1 replace and test until you find the bad one/ones.
Thanks, Thats what I was looking for.anlasak wrote: Here you go.
Modified by anlasak at 3:44 PM 10/12/2006
Q45tech wrote:Coils which partially fail or just have below limit high voltage that occurs randomly are very difficult to test..............a normal failure will show up as a OBD2 code.An abnormal [unfortunately common] weakness will require the substitution or just total replacement.............you can spend an hour getting the test equipment connected and still not simulate the conditions where the failure occurs.
Many times just removing the coils cleaning them up of oil film replacing the plugs and reassembly will solve many problems for awhile.
Misses at cruise are easy as the OBD2 watches O2 for a rich cylinder and reports that cylinder as a misfire................accelerations and idles or WOT misses are more difficult and beyond the ecu's mental powers to resolve [system not in closed loop].
2002 and later have enough computer power to almost always zero in better even when not in closed loop.
Great info! Thanks Tech.Q45tech wrote:Coils which partially fail or just have below limit high voltage that occurs randomly are very difficult to test..............a normal failure will show up as a OBD2 code.An abnormal [unfortunately common] weakness will require the substitution or just total replacement.............you can spend an hour getting the test equipment connected and still not simulate the conditions where the failure occurs.
Closed LoopQproject wrote:q45tech, what do u mean by closed loop of the obd2 ?
My coilpack failure was only at elevated operating temperatures caused by high ambient temperatures (>95° F).Q45tech wrote:An abnormal [unfortunately common] weakness will require the substitution or just total replacement.............you can spend an hour getting the test equipment connected and still not simulate the conditions where the failure occurs.
Try a search on Bosch and you will rip them out after you read the posts.Q_SHIP wrote:What are the chances that my issues are coming from Bosch plugs? They perfeormed flawlessly for 20,000 miles. Could they just be shot at this point? I pulled them all and all the electrodes are still there.
Best to correct the car's deficiencies in diagnosing your problem.Q_SHIP wrote:Well, I pelpaced all the Boschs with NGK's. Same problem. Cost $110 but atleast they are the right ones now.
The sacanner I have just came up with "random multiable misfrires detected"maxnix wrote:Best to correct the car's deficiencies in diagnosing your problem.
Have we missed your post of the OBD II scan?
OK, I am an OBD II dummy, but when I got a scan, the particular cylinder misfiring was identified. Which code was displayed? Are you sure of your scan tool?Q_SHIP wrote:The sacanner I have just came up with "random multiable misfrires detected"
I was thinking "well I could have told you that"
