knightrider »
https://forums.nicoclub.com/knightrider-u3208.html
Sat Feb 21, 2004 7:27 pm
manufacter date. early motors had 9.1 compression. later single cam motors had 8.6:1 compression, i believe an easy way to tell is if you have a air temp sensor, you have the 8.6 compression both motors have the same bore, stroke. meaning nissan prolly started using a thicker head gasket, or changed the head design for lower compression, they also changed the ecu
nissan technical bulletin TS89-072 covers the compression change.
