:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Nov 11, 2004 1:44 pm
Bronze MFP is correct...on S14 SEs...ABS/VLSD was a package, only way you could get either.
As for the diff fluid...it doesn't matter. The viscous unit is a SEALED unit, so you do not need any special fluid or additives. They all use 80W-90, GL-% oil...I like Mobil 1 gear oil, or the Valvoline Semi-Syn. Each can be had for $6-8/quart, the diff holds ~1.5 quarts.
- Brian
