How do I take off the door panels on my M30
Tylerfugate
Car: 1992 Infiniti M30 Convertible 77k miles
Hi I have a 1992 Infiniti M30 and I want to change the old crackly speakers in the doors but I cant seem to find any screws or clips around the panel, I saw on a website a guy wanted $4.00 for the info but that seemed shady. If you could help that would be greatly appreciated. Thanks!
Kompresshun
I don't have any direct experience with removing them, but usually what I do is find all of the screws attaching it first. They're typically hidden under little plastic covers around the arm rest and bottom of the panel. Sometimes there is one near the top front of the panel too. Once you do that, use a thin, wide screwdriver or putty knife and wedge it between the panel and the door. Gently pry back, working your way around the panel and you should be able to pop it loose. Don't force it, or you may end up breaking something. I'd recommend starting in one of the lower corners too. You also may need to remove, or pop loose the bezel around the door handle. After it's loose, it should lift straight up.
Let us know if that helps!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Take a look at the BF (body) section of the FSM at about page BF-24. Be warned that the link takes a long time to open.
http://www.nicoclub.com/FSM/M/1992_M30/
Tylerfugate
Thank you soo much I got em off today! I really Appreciate your guys help!
