how do I set to TDC?
m1dt0wn3
how do I set my ka24e to top dead center? what do I have to crank and what do I have to look for?
Silvia007
Car: 93 Nissan 240SX SE Fastback
Look on the main pulley, turn it and you'll find 6 lines on the main pulley, There will also be a metal rod sticking out of the block. What you do is turn the main pulley till the 2nd line from the left is aligned with the metal rod and that's top dead center.
