C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Oct 13, 2006 1:43 pm
I'm thinkint you are referring to the studs, but to confirm, are these threads the ones you will be using to tighten the turbo to the manifold using nuts on them, then that are indeed studs. If they are too tight to remove by hand, get 2 nuts that fit the studs and screw both onto one stud. Then tighten the 2 nuts to each other. Use a wrench against the lower nut to loosen it and it should come off. Then loosen the nuts from each other and then repeat the process for the other two studs. To put one on do the same thing, but tighten them instead. You migh use some penetrating oil on the studs before you do this in case the studs are siezed at all.
Some hardware stores will carry replacements. Not as many though if they are Metric threads. If they are the same thread as the studs that attach the exhaust manifold to the heads, then you can get some from the dealer along with matching mechanical locknuts(I highly recommend using mechanical locknuts to keep it from loosening).
If they do not match the above description, try to explain it in more detail or take pics and post them up.
