OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Thu Sep 01, 2011 8:17 pm
the SRS reset procedure for a 99 i30 is to start with key turned off.. I did this after I had the front seats out..
1) Turn ignition key to on - SRS lights up.
2) Tap the door light switch 6 times in 10 seconds.. usually the SRS light will go off after the 6th tap. Some models require 10 taps in 10 seconds.
3) turn the key off
4) wait 10 seconds
5) start car and the light will go off normally..
It took a couple of tries to get the rhythm of it before it worked for me..
