Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Feb 09, 2005 8:18 am
No, my slave was working fine, but in an attempt to bleed the clutch hydraulic system I broke off the bleeder screw in the cylinder. Since the fluid was filthy (probably OEM) and really needed to be changed, I decided it was time to just get a new slave cylinder. The speedbleeder is a special bleed screw that has a one-way valve within it, so you don't have to worry about drawing air back into the system when you bring the pedal back up. The stainless steel line gives better feedback from the clutch since it doesn't expand slightly under pressure like a rubber line, and it's also much more durable than the stock line. My clutch damper box was removed also.
Keep in mind that if your slave is leaking, every time you push down the clutch pedal some of the hydraulic pressure that would be actuating the slave cylinder and vis-a-vis the clutch fork mechanism is instead being lost as the fluid escapes. In your situation it sounds like that is causing the the clutch to not fully disengage, which would make for a hard shift.
