How do I replace headlamp assembly?? Can't remove old one.
osu9400
Car: 2002 I35, 98 QX4, 97 Nissan Truck
I have new lamp assemblies for my 2002 i35. There are two screws on top which are visible. There is one more underneath which I cannot access. How do I get to this last screw???
Kompresshun
osu9400 wrote:I have new lamp assemblies for my 2002 i35. There are two screws on top which are visible. There is one more underneath which I cannot access. How do I get to this last screw???
You have to take off the splash shields underneath the car and you'll be able to see it. They're a bit of a pain to get off but once you get them off the third bolt with be visible and shouldn't be too hard to access.
Markc
Car: 2008 m35x
2005 infiniti G35
Just curious. Why do you have new lamp assys? They're real expensive.
osu9400
Thanks for the replies. I looked underneath and there are some clips which I cannot remove without breaking. Is there a tool or some technique to remove these clips?
My original covers are completely fogged over and quite ugly. I bought some new after markets for $85 each. Very nice looking!
Markc
Car: 2008 m35x
2005 infiniti G35
All the FSM says is to "remove bolts and hook" securing headlamp assy. Not very helpfull I'm afraid.Got a link to the aftermarkets?
osu9400
http://cgi.ebay.com/ebaymotors/00-01-04 ... Markc"]All the FSM says is to "remove bolts and hook" securing headlamp assy. Not very helpfull I'm afraid.Got a link to the aftermarkets?[/quote]
Kompresshun
osu9400 wrote:Thanks for the replies. I looked underneath and there are some clips which I cannot remove without breaking. Is there a tool or some technique to remove these clips?
Use a flat head screwdriver and there should be a slot in the clips that you can fit it in from the side. Basically it's a 2 part clip, you separate it(gently) with a screwdriver and then it will pull right out.
