How do I remove the top belt on a 89 KA24E
1rst240sx
Car: 1989 Nissan 240SX
Hi thank you in advance for any help
My top belt needs replacing, I unscrewed what I thought was the tensioner pulley bolt but after unscrewing it all the way and nothing happend lol I thought I might ask.
[pulley] [tensioner]
[crank]
1rst240sx
I have read pump replacement as an alternate and they dont list my year and the pulley system is differnt
I dont have a lower tension bolt
my pulley sits protruded from the block by a bracket
carkook
Loosen the bolt that holds the pully to the bracket, it locks the tensioner, send me money.
1rst240sx
carkook wrote:Loosen the bolt that holds the pully to the bracket, it locks the tensioner, send me money.
EDIT FOR Perfessional Courtsey
I will pay you NO money
I need better advised, the bolt was removed all the way and the nut holding the pulley onto the tensior was removed as well.
and besides the 3 bolts is all that pull does
Modified by 1rst240sx at 8:21 PM 10/22/2008
1989240sx
Car: 1989 240sx and 1974 duster
loosen the bolt that hold on the pull than there is a bolt that will loosen the belt i know i have just got done doing timing chain on my 89 240 also if you are having problems with getting belts off you might want to rethink about doing your timing chain yourself and get someone that know little bit more than you
1rst240sx
Thanks for the advise lol all that stuff has been done and more, I have done most of the work on the car myself.
Im thinking that my tensioner is broke though cause now the bolt just threads down by itself, so Im looking at alternatives.
Sorry to anyone who reads the harsh post earlier, having a ****ty day and I drive my car over 50 miles aday and is kinda in a hurry to fix it but meh o well ill figure it out.O and the bolt that holds the pully to the tensioner part just loosens a nut and that was taken off as well and besides the 3 bolts that hold the braket to the engine block thats it.
Thanks though, just a little preventive maintence
carkook
now apolagize hahahah
1rst240sx
Im sorry for my post earlier , im having a really bad day and I fell dumb for this thing kicking my ***I think its broke now though cause the bolt threads down without me turning it down and I can unscrew it by hand
carkook
1)Loosen bolt that holds the pulley itself, it locks the tensioner in place.
2)Loosen the tensoiner bolt as much as desired.
3)Pull on the belt or tap(might take a good amount of force) on the tensioner bolt or the pulley. Pulley should budge and be able to move.
There is nothing that could hold if you are doing this correctly, and on the same tensioner
1rst240sx
Thank you
Wadda I owe ya
