goody94q45 wrote:There's a wire snap ring holding the bulb in place. Bent needle nose pliers work good to loosen one leg of the snap ring at a time and it swivels out of position so you can remove the bulb. Bring a mirror with you on your next attempt and it will all make sense. Good luck.
Wow, thank you soo much Goody! I can't believe I didn't think of that. I've got some stupid rubber cover all around it so it was hard to see anything without tearing it all up. I would imagine thats necessary for weather proofing so I did not want to damage it.
