How do I remove the lower intake manifold?
Dadspathfinder
Hello, I'm currently removing my lower intake manifold in order to get to my knock sensor. I've had already removed my fuel rails, and screws/allenwrenches that bolts the lower manifold down. However, I am running into a tiny problem. There happens to be a little piping that the lower intake have that somewhat attached or plugs into a metal wall facing the direction of the radiator fan.
How do I get this off? I've been trying to rock this manifold loose by shaking it back and forth. But, it's not coming off because there isn't enough room.... and the screws that holds it in place requires you to lift directly straight up and I cant do that with the piping attached to the wall. See pictures.
https://gyazo.com/4238722633deda7a4f5560a3d7b5a1e7
https://gyazo.com/2788f4ab4657c348937018a1e053df08
Throw us a year / model so we can pull the correct FSM for you. Or, pull it up for yourself at nissanservicemanuals.com
Welcome aboard!
