how do I remove the front timing cover on my ka24e?
crypt2k
Car: cars, women, what else.
I took out all of the bolts... and i cant seem to pull this thing from the front of the motor... i think its because of the sealant used but man... its hard as hell.
you guyz got any tips on removing this?
thanx in advance.
Nick_240
Car: Playing guitar, and cars
The timing front cover is on tight, I used a hammer and pryed it using the intake manifold as a pivot point.? just be careful of the intake manifold, and of the head gasket, and the oil pan gasket, and the oil pump and the distributor....
I fixed the timing chain guide on the engine, and it cost me $900... because the distributor and oil pump got misaligned....
DC2 GSR
When I changed the timing chain in mine, I had to raise the engine a couple of inches so I could drop the oil pan. There are 2 studs on the bottom of the timing cover that go into the oil pan..... that part isn't fun because trying to re-seal the pan gasket afterwards is a pain in the a$$. The oil pan will not come right off the car because of the oil pump pick-up tube.
Good luck..... my 1 day timing belt job ended up taking almost 3 days.
Nis240sanSX
Car: cars, motorcycles, music, playing guitar
Yeah, you just gotta pry hard, but be careful at the same time, also double check that you have all the bolts out and don't forget about the tube that goes into the oil pan, that has to be disconnected too.
