How do I remove the corner lights?
Vince C
My right corner light went out and I cant figure out how to remove it. The only screw I was able to locate was the one on top next to the headlight, what else holds it in? Thanks for any help!
xxcrashxx
Car: 95 Infiniti J30
right corner light??? what does it do?? do u mean the runner light of the turn signal, or the high beams, or what exactly?? im thinking ur talkin about the runner light, as far as im aware, u should just be able to take a thin flat head screwdriver, put a cloth over(so u dont mess up the paint) and place it under one end of it, and pry it off.
94J30
Car: 94 J30
Vince C wrote:My right corner light went out and I cant figure out how to remove it. The only screw I was able to locate was the one on top next to the headlight, what else holds it in? Thanks for any help!
it comes straight out, there is a little fitting that holds it snug and lines it up but unscrew the one screw next ro the headlight, under the rubber strip and it pulls straight out.
DominickJ30
Car: 1993 Infiniti J30t
Once you have that screw out, you just have to pull on it.
driverdriver
Car: NICO's longtime resident Canuck!!!
If your afraid of loisng the screw (something I'm prone too!), you can also loosen it and simply swing it out to change the bulb.
Vince C
Thanks for the help guys, i was able to get it out.
