Nagalf »
https://forums.nicoclub.com/nagalf-u126663.html
Wed Aug 04, 2010 12:00 pm
Im not 100% sure on this I did it a while back but i check when the sun goes down but i think you have to it in oder the top first pull the down there should be like 3 clips or two screws holding it down o the the ends remove those. the the lower portion are clips also and you have to use light force carefully not breaking them. but once again ill check a bit later
