How do i remove a relay
naladude911
Car: 2001 Infiniti QX4
Its to cut off my DRl's, I dont like them, but I dont want them removed.
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
u push da lil tab in on the side and pull up. if you cant do this u shouldnt be around a car.
naladude911
i did that, but i didnt want to break it
Speedy7_7
Car: 2002 IS300 And 2008 Nissan Versa
xweav32 wrote:u push da lil tab in on the side and pull up. if you cant do this u shouldnt be around a car.
This is pretty simple man. Have you ever changed oil?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Moved this to IOM from NICO Gen Chat.
But the easiest way to remove the relay is to take a bladed screw driver and slide it on to the tab and then pull up on the relay while you use the screw driver to keep the tab depressed. Relays tend to stick to the bases, so you'll have to do some pulling and wiggling, but once it releases, it'll come out easily.
Also, your camera needs better macro focusing. Or you need to stand further away and use the zoom function
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, most definitely not a camera!
naladude911
ok. Umm, i was able to take the cap off, but the base is still snug in there. how do i take it out? (btw, even with the cap off, DRL's still work)
Q451990
It should come out as a unit... it sounds like the top separated - but I've never seen that. Might want to post another pic?
Heath
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
Sounds like it may now be toast. How about some needle nose pliers? Or needle nose ViceGrips? Maybe a quick shot of Miracle Jizz at it's base will help.(PB Blaster, AeroKroil, Liquid Wrench etc)
naladude911
ok il try again. so i pulled out the top, and grabbed the base and pried and pulled. nothing. so il try pliers
