How do I rebuild a ka24de?
Ernest2700
Car: 91 Nissan 249sx se
I just bought this performance rebuild kit and am getting started tomorrow on taking the engine out to rebuild it obviously. I don't have a manual for the car and I'm new with the 240 I bought it at the end of February with a knocking sound that onl occurs at 2.5rpm-3.5rpm so i bought a kit to make it purr. The only problem is I search and all i get is cites selling rebuild kits so I'm here with the question of How do I do it? Is there a dummy guide somewhere? Please help me out
Also I'm overhauling the transmission soon and ordering stock t28 nissan turbo kit this summer to never be able to get traction in my first 3 gears or whatnot.
Some help or info please!
91 240sx Ka24de 110,000 miles
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Rod knock ayy... I hope your having it bored and decked. Is your rebuild kit an overbore kit. You need to drop that block off at a machine shop.
Ernest2700
It's .02 over I had it checked and with the wear in it they fit clean. Plus if the mechanic is wrong I can swap for stock standards for free. I got the kit from http://www.performance-auto-pa...n.php
just look for the 2.4L 1991-whatever major kit
too bad I'm a noob and the kit didn't give me instructions...
95silvia14
Car: 1995 240SX, 1993 s13 coupe
get the fsm off of here matter fact heres the link
http://www.nicoclub.com/fsm/240sx/91-94/
vancouverbc
Car: 1991 240sx
there is some pictures of rebuild under engine in tutorials in my signature.
vancouverbc
Car: 1991 240sx
zerothread?id=272493
another thread on teardown
Ernest2700
Thanks so much! Appreciate the posts!
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
You will need a large allen key fitting(s) for the head bolts.Torque wrench.You will need a honing tool, and a friend at times to help lift the head out.Also a piston ring expander for ring install.Evaluate how 'good' the pistons look, new ones aren't too xpensive if they're bad.Just listed some of the common necessary things that are overlooked for ya. GL, it's easy man just follow your nose.
kokujo17
Car: 91 Nissan 240sx Coupe, 99 Dodge NEON
you know you could always buy a book on the car that tells you everything you need to know . I got one for myself, its made by chilton and the book has repair manuals for the stanza and 200sx in it as well, so you'll get some nice info on ka's, ca's and vg engines.
Ernest2700
Tools is what I really need to know man. Thanks.
24j0hn
Car: 91' 240sx with some babying to be given
Ernest2700 wrote:knocking sound that onl occurs at 2.5rpm-3.5rpm so i bought a kit to make it purr
that knoking isnt rods or anything like that... i removed my timing chain guide and i doesnt make a sound at idle but around 2.5 rpm it makes that knoking sound... its just the thiming chain.... but since your going turbo its good your rebuilding... imo you should replace the timing chain also, if it doesnt come with the kit already... then itll purr
SILVIAJayS
Car: 1996 Nissan 240SX SE
This was helpful to me:
http://www.ka-t.org/forums/viewtopic.php?t=4156
Also check out 240sxtechdvds.org, he's got a full ka rebuild dvd coming soon.
kokujo17
If it's tools you need go to a auto store and buy a big set of tools you can of sockets. Then after buy whatever other sizes you need. Remember to get a pully puller, seal puller and valve spring one too if your doing that as well. Just so you know most bolts are 10mm to like 15mm.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
10-12-14-17-19-23-32mm
S13Teddy
Car: R32 Skyline, S13
This will help.
greencar
Car: 1992 240sx se
Ernest2700 wrote:It's .02 over I had it checked and with the wear in it they fit clean. Plus if the mechanic is wrong I can swap for stock standards for free. I got the kit from http://www.performance-auto-pa...n.php
I bought that kit, it is pretty nice, here is a link with big pics, it helped me out quite a bit!
http://www.importfanatix.com/F...t=442
visser003
Car: 1991 Nissan 240sx Coupe
24j0hn wrote:that knoking isnt rods or anything like that... i removed my timing chain guide and i doesnt make a sound at idle but around 2.5 rpm it makes that knoking sound... its just the thiming chain.... but since your going turbo its good your rebuilding... imo you should replace the timing chain also, if it doesnt come with the kit already... then itll purr
That COULD be it, but if he can't tell the difference between timing chain rattle and engine knock he shouldn't even change his oil :P well that's an exaggeration.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
AHAH! I see the problem right here!!! That lil baby's not even broken in yet!
driftneil
Car: A pile of cars.
! But besides the standard tools, you will need swivels, and a 10mm allen key socket(for the head bolts)
ProjectCrazyS13
Car: 2002 SVT Focus, 1988 honda crx si, 1993 240sx se hatch, 93 240sx se coupe
i garantee the sound your hearing is a piston pin, my is doing the exhaust same thing, same rpm range too, it alittle harder of a knock then a timing chain rattle, and thats what mine is the piston pin. good luck with your biuld.
Matej
You can rebuild it. You have the technology.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
^^^ LOLOLOLOLOLOL
duffman1278
Car: 89 240sx Hatch, the wildcats!
You need to do your homework before you take on a task like this, the last thing you want is rod knock again right after you've rebuilt it.
myfirst24010
Car: 1993 240sx, 2004 BMW M3,
lol WTF!!!!
S13Teddy wrote:This will help.
Dire91
Car: 1997 Nissan 240sx SE
This might helphttp://www.240sxtechdvds.org/index.html
DMan II-40
Car: 1995 240SX SE
myfirst24010 wrote:lol WTF!!!!
You really bumped an old as thread to say that......
Wow, people's stupidity these days. I'm scared of our future.
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
Didderson wrote:just follow your nose.
That's what she said.
240dx
Car: '97 Nissan 240SX LE
OutToWinPAHC wrote:10-12-14-17-19-23-32mm
Very familiar numbers Whats the 23 for?+and add a 27
NeoTokyo
Car: 1992 300ZX 2+2 5spd TT Swapped Wide Body
DMan II-40 wrote:
Mon Nov 02, 2009 2:02 am
If you thought bumping an old thread after a few months was bad, HOW ABOUT AFTER 15 YEARS?! MUWAHAHAHAHAHAHAHA!
