schumachergt1https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113HOW DO I READ TORQUE SPECS ON A FSM from nicoclub?Fri Nov 11, 2016 11:49 am
Postby
schumachergt1 »
https://forums.nicoclub.com/schumachergt1-u269512.htmlFri Nov 11, 2016 11:49 am
New member here, but knowledgeable about cars........I have a 2000 altima w/ the 2.4L and downloaded the FSM from here......going to change the thermostat and need to know how much to tighten bolts to put back the water inlet while reassembling.
Postby
float_6969 »
https://forums.nicoclub.com/float-6969-u780.htmlFri Nov 11, 2016 6:52 pm
I don't want to download that specific FSM to make sure, but all of the other Nissan FSM's have 3 different torque specs listed. IIRC it goes as follows; Nm(kg/m, ft/lbs). There's also usually a key down on the bottom right of the page illustrating that on the parts explosions.
Postby
schumachergt1 »
https://forums.nicoclub.com/schumachergt1-u269512.htmlSat Nov 12, 2016 6:55 am
hey Float, thanks for the reply any way you could send me a private message? i have the specific page downloaded and could email or share with you...........let me know, no worries if not
