NISSAN240SX12 wrote:have you tried doing a dry crank. disconnect the fuel pump fuse and ignition coil wire. and just crank it to prime the the oil in the engine
yes I should of added that, I did try a dry crank about 10 minutes worth total so far.
This is driving me nuts, it blows my mine how a oil pump could just fail from sitting in my garage?
I have powered about 15 quarts of oil through it and seems to flow through just fine with no blockage.
I also replaced the sump/filther today with a new one and still nothing.
Anything special anyone can think of that I should be looking for?
