How do I pop this sucker out?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
I want to use this blank socket for my on/off switch for my foglights but I can't pop it out for the life of me. I can get the side mirror controls beside it out but not the blank socket.
Ideas?
NODES
Car: 2007 Nissan Versa SL (Blue)
push it from the back by removing the lower dash piece. I am shocked it just does not pop out from the front.
williamk10
NODES wrote:push it from the back by removing the lower dash piece. I am shocked it just does not pop out from the front.
By lower dash peice, do you mean the fuse panel cover? I can just barely touch it if i run my hand thru the fuse panel since the opening is rather small
NODES
yeah that is what I meant the fuse panel. Maybe use a screw driver and instead of your hand to push it out
Jon-jon
Car: 2009 Nissan Versa S Hatch
Did you manage to pop it out yet? I tried what NODES suggested earlier today with a screwdriver, and it still wouldn't budge...
williamk10
I got it out
there are tabs on the top and bottom. Just use a flathead screwdriver and lift one of the tabs up. Then push the cover from the front and it'll pop into the dash. You can get it from the fuse panel area afterwards.
NODES
Jon-jon wrote:Did you manage to pop it out yet? I tried what NODES suggested earlier today with a screwdriver, and it still wouldn't budge...
lol I guess that is the only part of the car that will never rattle
Jon-jon
Thanks guys!
NODES
If I ever end up getting a switch for mine I would buy the OEM stalk and wire my fogs into the pre installed wires. (I know this will only work for pre wired cars)
I personally hate aftermarket type switches.
Jon-jon
yeah I definitely agree, I would definitely go for the oem route. I wish my wallet would agree with me haha
NODES
Jon-jon wrote:yeah I definitely agree, I would definitely go for the oem route. I wish my wallet would agree with me haha
I would still use the walmart fogs though.
Versa357
Car: 2009 Nissan Versa 1.6 Sedan
I would actually like to have a aftermarket switch. Then you can put the fogs on anytime you want. You could have them on with your high beams if you wanted or you could turn on just the fogs with no other lights. The 2nd option is nice when you slip down a ally trying to ditch the cops so they dont see any tail lights...lol .Just joking of course but I like the flexability with a aftermarket switch.
reyes1212
Car: '07 Nissan Versa Super Black
I just rigged mine to turn on whenever I turned on my parking lights.
Codelicious
Car: 1989 Nissan 240SX
reyes1212 wrote:I just rigged mine to turn on whenever I turned on my parking lights.
good idea!
How would yiu do that though? Did you just connect it to the fuse?
Return to “Versa Technical Discussions”
