UsedToOwn240SX »
https://forums.nicoclub.com/usedtoown240sx-u5163.html
Wed Aug 27, 2003 8:16 pm
Just a reminder, you might have done this. But, did you take all the sparkplugs out when you crank? With no compression, the motor (thus the oil pump) will crank at higher RPM then you'll get oil pressure faster providing your oil pump is good. When I primed my motor, it took me like 4 20-second cranks. As a note, if you have electrical oil pressure gauge, it'll be off when you crank. As soon as you stop cranking, it'll jump up to some PSI and starts descending.
