Ok i really need advice here, this is my second KS i've gotten that ain't working for me. The first one i put in the OEM location and it made the car surge on rpms with no power till 3k, The second one i relocated to the top where the ground bolt is for now until my bolt comes in to relocate it to the back plenum bolt. I relocated the ground wire to the top of the ks but i don't think it would screw it up would it, I would imagine i could just ground this ks to the firewall (not that i would) and it would tell the pc all is good? I've tested the new ks and it shows about 578K ohms which from another post i saw is in operating range. It has horrible power until 3k whether the engine is cold or warmed up. I've pulled the ohm readings of the ks when the engine was luke warm as well. I've also tested it through the sub harness wire and all seems to be showing the same reading. For now i've put the 1k OHM resistor in there to bypass it but it's still eating up gas and i use this car at my second job for delivery and gas is killing me. I might step down the resistor to around 600k ohms to help but really would like to make this correct, I've tried 2 times now and am back at step 1 still. Any Ideas why this is happening? Any other test i can do? Maybe two dud sensors in a row? Pictures follow
Also i've used the dielectric grease to and no help, but like i said i've tested it through the sub-harness and have 578k ohms and have continuity between the right pin (ground) on the KS and body ground.
