AN89HATCH »
https://forums.nicoclub.com/an89hatch-u15073.html
Thu Apr 29, 2004 10:42 pm
I have a Te04h, witch is alittle bigger than a t28, I know its small, but it was free, Im going to run 4 - 4.5 psi, With a revlimeter set at 5K rpm, so i do not over rev the turbo. (not looking for high numbers) I am wondering, how do I get the stock wastegate to lower boost? I have heard of changing springs, How do you open the stock wastegate to change the spring? Would cutting the wastegate shaft, and shorting it be a better Idea, than changing the spring? If cutting the shaft is better, how do I know how much to cut?
