kbflip02 wrote:my car just hit 105000mi this week...since its just over 100000 i want to double check everything and replace what i need to before it breaks and causes more problems...any suggestions???ive already done the fuel filter,air filter,plugs,i had to replace one injector,ive flushed the transmission,oil,and fuel,am i missing something...i know i probably am...either that or im just too anal....there goes the OCD kicking in again...lol....any sugggestions would be greatly appreciated-K
You can change the rear diff fluid.
Did you have the transmission flushed or did you drop the pan, clean the pan and magnet, replace the filter, and install with new gasket? If just a flush, then it's time to change the transmission filter.
You can use a turkey baster and basically flush the power steering fluid out. Get all of the old out that you can, refill and repeat several days later untill it's clean. I like to add a bottle of Lucas Power Steering treatment when I do this.
You can use the turkey baster for the brake fluid. Get as much old out as you can, then put new fluid in and then bleed the brakes.
You can clean the throttle bodies.
I like to use 3 ounces of Lucas Fuel Treatment on every fill-up of gas. And of course, only use premuim gas.
Auto-RX is an awsome product to help clean the internals of an engine. Go to their site and look at the before and after pictures of the 240 sx engine. Amazing. (I just got done treating mine with this stuff.)
Another product that I like is Seafoam. Use it in the intake manifold to help clean the top of the engine. Can you say smokescreen?
There's a few more for you.
And you think you have OCD? Everytime I get a new (to me) vehicle, I change EVERYTHING!
