how do i know if my oil pump is going out?
corey240
Car: 1993 Nissan 240SX Base Drift Machine
how would i find out if my oil pump is going out or is already? would there be a noise? would it show on an oil pressure gauge?
ser2102
Car: 91 dead. 90 getting did
and oil pressure gauge would show it. it would be a big drop in Psi. also if youre losing pressure, you will hear strange noises coming from the head. lots of ticking from the lack of oil.
corey240
yea i hear that, the problem is i have this ticking coming from the head, i rthought i bled the lifters good enough, so im gona do them again when i get the chance, the ticking noise is coming from the front area of the head, to replace the oil pump, you gota pull the headand oilpan dont you? (among other little things)
karmakaze
Car: 98 240sx SE
if you even suspect that your oil pump is going out, then replace it. its not worth the risk.
corey240
thats the problem, i dont know if i suspect it or not, so if i gt an oilpressure gauge what should it be reading?
slowasss13
Car: s13 sr20det tomai o2 housing blits down pipe hks pro power exhust greddy v spec inercooler 6 puck s
the oil pump dose not creat oil presser the cleaence between the bearing creat presser the pump just creats flow.(but if u ant got flow u ant got presser).....after the car if warmed up any thing below like 18 psi at idle is low and the faster u turn the moter the hight the presser should be .... hope this helped
