How do I know if my differential is on its way out on a 1993 Q45?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
How do I know I have a bad differntial?
When I changed the differntial fluid a couple of months ago I notice that the magent was filled with little metal particles, But half of the fluid (The top part (Or the last part of the fluid to come out) ) Was clean.
But it seems that when it snows out or there is ice out the back end goes to the left and ONLY the left, should'nt the back end go to the right as well as the left?
Q451990
The usual sign of a failing differential is a howling noise from the rear end - varies with speed.
Heath
Infinitiguy19
Yay me then, I think tires might have something to do with it as well.
Becuase if you have one tire that is crappy on the right, The left will get most of the torque causing the car to go to that side right?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Paul Wall wrote:Becuase if you have one tire that is crappy on the right, The left will get most of the torque causing the car to go to that side right?
If you are dumb enough to run unmatched tires on the drive axle, either your VLSD will wear faster, or your brake pads will do to TCS operation.
Just totally inconceivable.
Is Paul Wall Peter Pastos on Drugs?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Q451990 wrote:The usual sign of a failing differential is a howling noise from the rear end - varies with speed.
Heath
The sound may also come and go dependent on load on the diff. Sometimes the howl will only present under accel or decel but not both.
Infinitiguy19
maxnix wrote:If you are dumb enough to run unmatched tires on the drive axle, either your VLSD will wear faster, or your brake pads will do to TCS operation.
I take it you read my other post about you.
But my differntial is fine, I just switched to snow tires (Michelin all round) And yes they are all the same size.
Q45tech
I am on differential #3 now, as to expect VLSD to last more than 100-120k is wishful..............noisewise most can make it to 200k with good lube change habits.
Finding low US mileage wrecks is almost impossible now............I found 2 in 2003 used one and kept the other for future.
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
Any way to check if VLSD is still good once removed from car?
Q45tech
Depending on traction control/active or standard VLSD version probably a lot easier to buy a $2500 new one than to find a fully functioning [as new] used diff.
Testing off car is difficult and inconclusive.
