DJ_SLapo »
https://forums.nicoclub.com/dj-slapo-u148164.html
Sun Nov 22, 2009 9:04 pm
You'll need a screw driver 10 and 12 mm sockets and drivers from them. also a extender for the driver
B/c we are working with stuff that deals with power. Disconnect your battery.
next remove the door card. There is a screw to the right. This will be covered Also, Remove the handle and window switch. It will be covered. That is also a screw. lift the handle from the handle side with your window switch if I can recall right. Next disconect the wires running to it. Then you can remove the card by pulling up from the bottom.
After all that this is what you get to seeDisconnet the amp and remove the amp and handle. (the black thing is the amp) These are screws
One more screw and your set.The last screw is for the weather strip. Its going to be on your top left.I removed this b/c the glass all gets stuck on it and rips all to little parts.
The regulator itself is held in by four bolts. Two top center one and two bottome one off center to the right.
The top ones
The bottom ones
B/c you still have your glass installedYour need to remove these screws. These screws are for fitment. How high they roll up. They can be found on the top left and right. They have two parts to them. The L looking things and the screw. Very hard to put back in. When putting everything together the "L" should be upside down. Letting the dish thing on the window up.
I forgot to add disconnet the connector to reulator
Everything disconnect or removed just wiggle it out of place.
This is a very fast write up. More like a guideline. I'm not responsibility for any damages done to your car.
good luck
Modified by DJ_SLapo at 11:49 PM 11/22/2009
