How do I install the ABS brake pump for my 1992 Infiniti Q45?
jshamrock2012
My ABS pump needs to be replaced and I like to work on my car myself, but I just dont know how to replace the ABS pump in my car. Any Help?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You might consult the 1994 FSM as the units are similar, but I believe yours has a bleed screw.
http://www.nicoclub.com/FSM/Q45/
Welcome to NICO!
Modified by maxnix at 11:14 AM 10/23/2008
Q451990
It's pretty much an unbolt and bolt in operation... just be sure to get a good 10MM flare wrench (e.g. Crafstman) for the brake lines. Lesser ones will tend to flare and strip out the collar.
Good luck!
Heath
