How do I install CAM ANGLE SENSOR>>??????????
k4rr
Car: 89 dodge ram truck
KI took it out and put it back in and now my car wont start..........
Please help I need my car for work tomorrow!!!!
Modified by k4rr at 7:03 PM 4/9/2007
Joe
k4rr wrote:I took it out and put it back in and now my car wont start..........
why did you remove it?
and the cas is keyed so it only installs in 1 direction. if that key broke off you can install it WAY off. look inside the CAS and see if the half moon shaped key is still there.
and you are going to need to reset your timing once its back on and running. hope you have a timing light.
mello88
Car: s13
Step 1: Obtain FSMStep 2: Read FSM
There is a key on the exhaust cam and a matching peice in the CAS... You can literally only install it one way, unless you've broken off the piece on the cam (which seems to happen to alot of us). In that case just line it up how it "should" be and push it into place. Finger tighten the bolts, plug in the connector, and set your timing with a timing light. Refer to step #1 and step #2 for correct procedure and # degrees.....
k4rr
Does my engine need to be a TDC when Install it???
I know it only goes on one way but where does the crank need to be!!!
I need a straight answer!
FSM does not have the info...........
Joe
k4rr wrote:Does my engine need to be a TDC when Install it???
no, this isnt a SR
and i gave you a damn straight answer. IT IS A KEYED SENSOR, IT WILL ONLY INSTALL 1 DIRECTION UNLESS THE KEY IS BROKEN. LOOK AT IT TO CHECK.
that clear enough?
and bull**** the FSM doesnt have the info. look harder.
k4rr
Crank angle sensor EN 355,356,404,442 those are the only sections the r32 fsm show any info about the crank angle sensor.......
It does not tell how to install it.
Is there another fsm I should be looking at????
Joe
ooook CAM angle and CRANK angle are 2 completely separate things.
k4rr
Well THE RB has the "crank angle sensor" on the exhaust CAM.
I just found out how to install the crank angle sensor!!!
I found it on a AUS skyline site!!!
Thanks for trying to help guys!!
k4rr
Oh yeah FYI
It has to be at TDC when you install the crank angle sensor.
JerryRigRB240
Car: 1990 240SX Coupe with RB20DET swap
Uh, no the engine does not have to be at TDC to install the CAS. All you need to do is spin the CAS to line up with the cam, wherever it is. It takes a little finesse to start it right.
You ask for help, but disreguard advice which is what is making people angry.
Honestly this isn't rocket science.
Joe
k4rr wrote:Well THE RB has the "crank angle sensor" on the exhaust CAM.
listen to what you are saying
install the CRANK angle sensor on the CAMSHAFT! hello?!?! dude?! common sense? why the hell would the CKP be on the CAMSHAFT?
thats the CAM ANGLE SENSOR
jesus!
k4rr
You are right I got wrong info about the tdc thing.
k4rr
Look in the FSM dummy!
The crank angle sensor is on the camshaft.
The cra
jesus!
Joe
that silver thing on the front of the motor, right?
i dont care what the upsidedown kangroo ****ers say, or what your FSM says. that is a camshaft position sensor. not crankshaft. try googling a skyline crankshaft position sensor, then camshaft.
