gbaz77 wrote:this is what i did and i think its even more simple than what the other guys said. sorry guys.
take the dash wire blue with black stripe, and have that ready to splice.
now look around your ECU for 3 other plugs. these plugs would have plugged into the r32 dash. two of those plugs have a blue/black wire, but one of those plugs has the tach wire, speedo wire, ign relay i think, and a blue/black wire. use that plug. in any case one of those two plugs should have it. if you can find the plug with the speedo and tach wire, then the blue/black one should work.
that is exactly what i just posted above .
fly240 wrote:so, you say it could be done right behind the cluster, just have to find the right wire?....
no that's not what he said, please read again...
