how do i hook up power steering on my 1990 rb20 240sx
ill300yourzx
Car: 1992 n/a 300zx modded out **SOLD my new friend rb20det s13
i have the rb20 in and running and i have the rb20 p/s resivoir and pump can i make it work I am not too technically inclined so if you had a picture specific that ouwld be good but any info would help I have a 3" down pipe and the steering rod rubs on it a just a little (doesnt affect the pipe I need your help thanks
I have another random question. Where can you get certified for a ferrari technician liscenced from ferrari? My friends father wants to look into it
Thanks
DeclareYrWar
http://forums.racebread.com/index.php?topic=1568.0 there ya go. cost is about $80 shipped for all the fittings if you buy from http://www.anplumbing.com/ much cheaper than dohc lines and wont ever leak considering that line is rated for like a billion psi lol. just dont forget to disable the hicas portion of your rb20 pump (search for a how-to on doing this. very simple)
ps. i'd recommend throwing on a p/s cooler while you're at it which is easy as can be, just get urself a decent cooler and put it in line with the return line going to your p/s reservoir.
gomer23
Car: 1989 Nissan 240sx
There is a guy on the board that makes custom lines for around 60 bucks (depending if you want a sensor or not). I just got mine the other day and looks like its going to work perfectly.
zerothread?id=307781
yotik
Car: 240sx Hatch
DeclareYrWar wrote:http://forums.racebread.com/index.php?topic=1568.0 there ya go. cost is about $80 shipped for all the fittings if you buy from http://www.anplumbing.com/ much cheaper than dohc lines and wont ever leak considering that line is rated for like a billion psi lol. just dont forget to disable the hicas portion of your rb20 pump (search for a how-to on doing this. very simple)
resurrected.
that link isnt working. anyone have a definitive guide to hook up power steering. i have a custom high pressure line, but on the return the sizes dont match. i also tried using the lower return flange from the ka24e but i found out the rb20 flange surface is flat whereas the ka24e isnt. is there a way to hook it up without fab work?
ANVIL
Car: RB25DET S13.5
i just got the ps lines from a dohc ka and it bolted up no modifications needed. works perfect
xDRFTurR1D3x
Car: 98 kouki- S2 RB25- f*ck you fed ex and mother nature!
93 s13.4 kouki/coupe- bottle fed modded KA- VH45 almost ready!
x2 in my kouki. only diff is i coiled the lines to the pump (without kinking it!). an bolted it back down upside down
yotik
Car: 240sx Hatch
did you guys use the dohc reservoir as well? the rb has that hicas pipe which i dont need. looks like the best thing to do is relocate it to the us drivers side too amirite? thanks guys for helping a rookie
rb24021
which i remembered how i did mine but it was so long ago lol..ill try 2 take some pics and post em for ya ps is def worth it..i HATED having manual steering lol.
yotik
Car: 240sx Hatch
that would be great
ANVIL
Car: RB25DET S13.5
used the dohc ps res in mine.
Sil240
Car: Nissan S13 "The One Cam Wonder"
I used DOHC lines but then my turbo discharge was going to be in the way.So I'm using the DJbutton line, with a PS cooler and DOHC reserviour with a larger drain.
I believe I posted pics up on here somewhere.
I still have the DOHC lines if you want them.
yotik
Car: 240sx Hatch
so what's different about the dohc lines and res? I was at the junkyard today and all I found were sohc models. and how muc do you want for the lines?
Sil240
Don't remember the difference between the reservoirs except for the fact they're on different sides of the engine.
You've got mail. <--- Email me. The email bounced.
[email protected]
Modified by Sil240 at 5:16 AM 5/6/2009
