How do i ground Neutral Safety Switch on Rb20det S14?
blues14
Car: 1995 Nissan 240SX GTS-t
How do i ground Neutral Safety Switch on Rb20det S14? this car was an automatic ka, then an automatic RB20, now its a 5spd Rb20 with auto ecu. I dont know if the shop that performed my swap did this or not.
blues14
anybody?
Carl H
ground the neutral safety switch?not sure what you are talking bout.
blues14
I read somwhere that when you convert auto to manual....you are supposed to do something with the neutral saftety switch. I thought i read 'ground', but i may have been mistaken. anyways, what , (if anything) needs to be done to the NSS?
gawdzilla
Car: none
near the fuse box theres a plug with some decent gauge wire, which is your park/neutral indicator on the auto. i think its the top plug on that stack row. you need to loop that plug so it thinks you're in P/N all the time
tecnic1
Car: 2004 sti
gawdzilla wrote:near the fuse box theres a plug with some decent gauge wire, which is your park/neutral indicator on the auto. i think its the top plug on that stack row. you need to loop that plug so it thinks you're in P/N all the time
IIRC it's the top plug, and it only has 2 wires goin into it...Just hack the two wires and splice them together
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
It def. is the top plug, I just did the 5 speed swap on mine...and now throwing the RB in it.
s13point5
Car: 89 240sx
sorry to bring up a REALLY old thread (hey atleast it shows i searched) does a s13 have the same plug in the same spot as the s14? im at work right now so i cant go out and look.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
yes its the same style plug etc.etc.
