BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Wed Jun 16, 2004 7:18 pm
1/4 panels are not cheap to fix or replace, the average price at the cheapest shop around here for a decent sized dent in a 1/4 panel to be pulled and painted is $250-$450. You get what you pay for, just remember that. Bondo is not a good solution to fixing a large dent, if you read the can it says not to put it on more than a 1/4" thick. Talk to whatever shop you choose to do the work, and make sure they are going to hammer/pull the dent out and not just fill it. All dents will need some bondo to do the final smooth out work once they pull the dent, because you can't pull one 100% smooth, the metal is now stretched so it won't return to its normal position.
Also, before you think about getting behind it and trying to push it out or hammer it out, realize that if you stretch the metal even more, it makes the bodyshops job even harder and may cost you more. I've seen $250 jobs become $350 jobs because the owner decided to try to get it out themselves and streteched the metal and caused a bunch of little dents inside of the big one.
