wickiewicked »
https://forums.nicoclub.com/wickiewicked-u18977.html
Sat Aug 14, 2004 4:48 pm
i went to the auto parts store got my self a 24 inch extension and a universal joint. the socket u-joint/ext is about $9.29 i did not have to remove any thing from the intake manifold. i just unscrew every single bolt i could from the transmission including the mounting bracket . just let the transmission go down, and you will have better access to the bolts........................................well im done with the swap its working great.... total time spent 1 week on swapprice for parts.......1990 5 speed transmission $55.00 and core $10.00clutch pressure plate $7.50 ...core $1.00drive shaft, 2pc. $15.00.... core $5.00yoke $4.50....core $1.00gear shifter $7.00....core $1.00manual mounting bracket $2.00
admission tax.........$0.16sub total $109.16environment surcharge $5.45recycling fee $4.55state tax $9.22grand total .............................................$128.38
i got everything at pick your part they had a 3 day sale 50% off so it was better for me................
autozone pilot bearing$7.99
clutch line $3.00clutch slave cylinder $9.00clutch pedal assembly $10.50.....core $1.00total $27.97 including the tax crap and other stuff..
clutch $102.99
replace your slave cylinger its only $21.64 including tax and kragen autoparts
the GRAND TOTAL IS ABOUT $323.52not including $2.00 each time i went to the junk yard and the oil use..................... good luck to anyone attenting this swap
