how do i get rid of the noise on the speakers?
Post all your Nissan electronics, car audio and stereo questions here!
Ren
Car: 1995 240sx
I had asked about this problem on my older thread.. but got no responds so i just post it again.. hope some1 will help.I am getting a high pitched whine in my system and it sound like there is static.
do i need a filter to get rid of the noise.. or there are better ways to do it?
if i do need a filter.. what kind and brands are recommanded?
thank you
Silvia007
Car: 93 Nissan 240SX SE Fastback
Hmmm sounds like either a bad wiring job or you are getting alternator wine. Tell us your setup, maybe we can diagnose it.
Ren
Car: 1995 240sx
I just connected the wires from the HU to the the hardness i bought, then connected them to my cars' hardness.. I think front speakers are stock.. the rear speakrs, the previous owner might had changed them.
Silvia007
Hmm... I would check his work. Make sure no bare wire is touching any part of the chasis in the back.
Ren
Car: 1995 240sx
I'VE CHECKED.. IT SEEMS A GOOD JOB.. ANY IDEA WHAT CAUSE THE NOICE?
base9se
Car: '95 240sx
Noise might be caused by the alternator. Made by Hitachi, which does not have a noise cancellator. When there is a high load on the alternator you will hear the noise.
sidewaySilvia
Car: check bio you eeediot
most likely it is alternator whine.. put a load on the alternator and see if the staic gets louder.. rev engine, put on ac , whatever it takes to draw more current the fizzz should get louder.. let us know man
BoBa524
Car: 1995 Nissan 240SX SE
when i hooked up an amp to power my back speakers, everytime i stepped on the gas it would whistle. i had a bad grounding place. check your grounding wire and try connecting it to diff places.
sidewaySilvia
hey ren. exactly what kind of sound are you hearing?.. alternator whine is probably one of the most common noises you"ll hear. be careful with your grounds though .. you dont want a ground loop. i"ll explain more to you as you send input to the thread.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys
sorry to resurrect an old thread like this but i got speaker static as well and this is the only thread the search turned up. so im gonna add my problem in here as well
my static is in all 4 of my speakers, i just installed my alpine 9833 unit and it seems to work fine, but whenever the unit is on and music is on as well then there is a steady static that is in all front/rear speakrs, doesnt go louder or quieter if i turn the volume up or down, nor does it go away when i fade all the volume to the rear speakers or the front ones
its really annoying although you cant hear it when you drive with music up
HELP!
btw. to wire i used the red connectors and crimped them reallllly hard, so i dont think the connections are ****ty..
TIAMax
PS. my stock sound system has the stock amps in the rear, so everything goes through that. could those 10 year old amps put the stable static in the speakers?
Modified by EstoMax at 5:45 PM 10/20/2004
