How do i get out the wire plugs!?!?!? HELP!
BarnDog296
Car: '93 Nissan 240SX SE Fastback KA24DE DOHC
Ok,I was changing out my spark plugs, and i guess I have now found out I HAVE to change out the wires also.The point is that when i was pulling out the spark plug wires, the plunger at the end that goes over the spark plug popped off and it will not come out. I tried to push the whole piece back in and try to reconnect it again, and it didnt work at all, of course. This is a big problem I currently have 2 different types of spark plugs in and that is not a good thing, as far as I know...
So, how in the world do I get the plunger out of there?is there a tool? a trick? what?
slc240sxse
Car: 96' 240sx SE
I would try to use a long flat bladed screwdriver and pop that little bastid off of the top. It shouldnt be on there too tight.
BarnDog296
No, its actually stuck inside the spark plug hole, its a pretty deep hole, and im not sure how to fish that thing out of there...
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
get a coathanger, bend one end, push it down the spark plug hole, and stab the end of the broken plug wire. should pop right out.
BarnDog296
Ok, i got it, i went and got a VERY long (11") set of needle nose and a really long flathead. I used the flat head to get the piece up on its side, and kinda unjam it, then used the needle nose to dig it out...
Thank god, now I can put in my NGK plugs :-D
240DRFT
i woulda just tried and used those magnetic things that are long
