Alright man I'll run to sears and check it out. Only problem is, I Can't fit any kind of tool in there without it being at an angle. So idk if the socket will work or not but hopefully it does.costa_rican13 wrote:its a socket called an extractor socket usually only come in sets. its, that or cut it, maybe torch it to persuade it alittle
Thing is, I just dropped the motor in about a month ago but I didn't think the motor mounts were this bad, they shake my trans so it doesn't catch gears half the time. But to sum it up, I don't want to pull the motor if I don't have to hahaS13_RB25 wrote:Well if you are going to take the engine out why dont you just unbolt from the engine side. And take the engine out, then you'll have enough room in there
I actually was able to use a 3 inch cut off wheel on the passenger side without having to remove anything. But I figured I'd have to take out that bolt that gets in the way and the tie rod which kind of pisses me offterry_240sx wrote:you could try what i had to do but it was a pain...
i first removed the driver's side tie rod (from the rack) and turned the wheel aside to get it out of the way.
then remove the bolt for the lower control arm about halfway to have the nut and bolt out of the way.
then get the smallest cut off wheel you can find (i was actually able to fit a 3 inch one) and keep cutting the nut and bolt off in small pieces. it eventually got so small i just knocked it off with an air hammer![]()
good luck!
