TakDrift »
https://forums.nicoclub.com/takdrift-u11924.html
Sat Dec 27, 2003 10:01 am
noetic1, did you fix your check engine light problem? I've found out by experience that the fuel cap, if defective or damaged or even not closed tightly, will make the car engine shake and turn on the check engine light. I usually close the fuel cap until I hear several clicks.
Hope this helps you out.
Greg
