How do I get Cam gears off camshaft?
preston240sx
Car: Nissan 240SX S13
Yea How do i get the cam spocket off the camshaft ?? can someone tell me how please thx >>>
nonchalant rage
Car: s12
take off the cam bolts, and then you may need to give it a little pursuasion for sprocket to come off.
XcreatureX
Car: 96 240sx SE
like he said bolt out should just come off
Seth
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
tap tap tapparoo to the sprocket with a 1" wrench
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
impact wrench makes life easy
onosqv
Car: '92 240sx Vert
justmerging wrote:impact wrench makes life easy
How the heck did you fit an impact wrench in the engine head area? much praise. I had the hardest time trying to get a regular ratchet/torque wrench when I was trying to get the nut from the cam gear to camshaft off on my sohc.
I also had the hardest time getting the damn thing not to spin w/ the turning of the ratchet (I have an auto - keep it at that ).
fiznat
Car: Grown up :(
If you already have the cam sprocket bolt off, it can sometimes get a little stuck on the end of the cam there. Just some light tapping with a rubber mallet should pop it off fairly easially.
Chezedik
Car: 1991 Nissan 240sx
I just took an adjustable wrench on the flat edges of the cam, put a ratchet on the end of the cam (for the bolt), and a six foot piece of pipe. After all, I believe it was Aristotle who said, "with a long enough lever, I could move the world".
Chezedik
oh, and leave it in the head, bolted down, that way you can jam your wrench against the side of the head, unless you feel brave enough to try to put a cam in a vise. Finally, I suppose if you had to (BAD IDEA!!!), you could leave the chain on it and hit the starter, like you might to take off the crank pulley.
