A_Rivers »
https://forums.nicoclub.com/a-rivers-u5693.html
Sat Feb 14, 2004 3:49 am
Hey man,
In relation to your headlight problem, I had an '87 Maxima that both high beams worked, but when I switched to low beams only the drivers side would work. I replaced the column combination switch because of a short in it and that solved all my woes, as sometimes the low beam would come on in the middle of the night and drain my battery. I bought my switch from a Nissan dealer but you might want to try an online parts dealer, just do a Google search for OEM Nissan Parts, replacing this part could also fix your turn signal issues as well.
Aaron Rivers
