HOW DO I FIX IDLING PROBLEMS ON MY 1990 S13(KA24E)
illestcreatedsoul
Car: 1990 s13
WHEN I START MY CAR IT IDLES ROUGH AND WILL DIE OUT IF I DONT GIVE IT ANY GAS, BUT WHEN I DO GIVE IT GAS AND WARM IT UP FOR A FEW SECONDS OR SO ITLL STAY ON BUT IT IDLES ROUGH. WHAT CAN I DO TO MAKE THE MOTOR NOT HAVE A ROUGH IDLE I HEARD IT CAN PUT IN ANOTHER GROUND HOSE AND JUST PUT EXTRA TAPE AROUND THE ORIGINAL HOSE BUT I NEED A MORE SPECIFIC ANSWER HELP ME OUT HOMIES.
Modified by illestcreatedsoul at 1:14 AM 5/2/2007
180fan
Car: 89 fastback
1. why did you make your entire post in caps? 2. if you're having a rough time at startup with idle, have you checked over the posts that involve cleaning the iacv? 3. adding more grounds can smooth out an idle, but assuming that all the necessary grounds are there, will not keep your motor from dying out on you. 4. last time doing a tune up that invovled setting the timing right, calibration of the tps, and replacement of the cts and a general cleaning of the mafs?5. if you've a sohc, have you checked that rubber hose that's just before the throttle body and after the plastic intake hose? are there cracks in the ribs or a tear in the hose at the ribs?
illestcreatedsoul
Car: 1990 s13
1. is there something wrong with that?2. im not familiar with this site yet3. ok4. got a tune up last week everythings fine5. none from what i can see
adrianfromthecastle
Car: 1992 Nissan 240sx
180fan
Car: 89 fastback
1. yes, poor netiquette.2. red button up top says "search"4. what was performed at that tune up?
could you elaborate on that "extra tape around the original hose" which hose?
180fan
Car: 89 fastback
adrians_s13 wrote:
well said. well said.
illestcreatedsoul
Car: 1990 s13
what was done during the tune up was really nothing they just checked the timing, belts, and changed the spark plug, and i believe the extra tape around the hose refers to the hose that connected to the iaa valve
KnoxVegasS13
Car: 91 Nissan 240sx w/S13 Triple Projection Conversion and SR20DET
I am having the exact same problem with my 240 but it has an sr20det and it was fine a week ago when we built it. I am very dissappointed and want to fix it before it does. Please help, thank you for your time.
adrianfromthecastle
KnoxVegasS13 wrote:I am having the exact same problem with my 240 but it has an sr20det and it was fine a week ago when we built it. I am very dissappointed and want to fix it before it does. Please help, thank you for your time.
haha wtf?
anyways... heres a list of things you can do to check- AICV- TPS- MAFS- vacuum leaks
KnoxVegasS13
What is the ACIV again? I have already checked timing and the MAFS.
adrianfromthecastle
air idle control valve. refer to your factory service manual (assuming that you already downloaded one)
180fan
Car: 89 fastback
well for the sohc, it's at the back of the intake manifold, the sr it's at the top of the collector below the 3rd and 4th runner. That one sucks to get to.
illestcreatedsoul
Car: 1990 s13
adrians_s13 wrote:haha wtf?
what and where are all these things located and how do i check them?
notslow
Car: Nissan Sileighty
1. Already explained in this thread2. Throttle Position Sensor (or Third Person Shooter if you're a Geek)3. Mass Air flow Sensor4. http://www.google.com or
The locations and details of all of these can be found in a Factory Service Manual.
