So I took the locking mechanism out and started fiddling with it and eventually decided that there was a rubber piece stuck in it that was stopping it from closing, so I started to get it out using a flathead screwdriver. Well I got about half of this rubber gunk out and then the latch started to work about 60% of the time, so I took the rest of the stuff out and then it worked fine, so i took the lock and locked it onto the truck 4 or 5 times and it worked fine, then all of a sudden it got hooked and now won't unlatch from the trunk...
I've spent the better part of an hour searching for a way to fix this, am I missing some god given article that shows how to fix this???
