thanks for the info. would i need to upgrade the injectors or anything else when putting one of those turbos on? how do i determine when i would need to do something like that? i apologize if these are noob questions, but i want to make sure i do this right and i want to be able to know when i would need to upgrade other aspects of the engine to support different mods. thanks again.float_6969 wrote:IMHO the best turbo for your application would be an SR T25 at about 12-14psi, OR an S15 T28 on the stock manifold at about 10-12psi. The T28 will make more power, but is kinda laggy. It's real bad if you use the SSAC manifold. If you keep the stock manifold it's not too bad. The SR T25 on the stock manifold is a very responsive setup and will get you right at the power level that you're looking for.
